Re: Farmall 450 Gas Engine trouble HELP!! :)
Posted by Bob M on July 02, 2012 at 14:48:24 from (69.207.87.163):
In Reply to: Re: Farmall 450 Gas Engine trouble HELP!! :) posted by Tony_Idaho on July 02, 2012 at 14:39:33:
#1 cylinder is at the front (fan end) of the engine. Run a timing check and report back what you find!
The good news: Replacing the cam gear is NOT that difficult - you need only remove the timing gear cover to get at it. It does however require removing the front bolster assembly (large and top heavy) which requires loader or engine hoist to safely handle.
