Re: Farmall 450 Gas Engine trouble HELP!! :)
Posted by CNKS on July 02, 2012 at 17:52:21 from (216.144.104.128):
In Reply to: Farmall 450 Gas Engine trouble HELP!! :) posted by Tony_Idaho on July 02, 2012 at 14:07:45:
Do the easy things first, rough running with no warning is usually a partially plugged outlet from the gas tank. Look inside with a flashlight and run a wire into the outlet. Also the screen you mentioned is in the inlet to the carb AFTER you remove the gas line. As a last resort drain the tank and unscrew the sediment bowl and clean it. You do NOT need a extra filter. The other things mentioned such as timing are not likely, unless you really do have a bad cam gear, which is also unlikely.
