1066 pto clutch
Posted by bnowen on July 02, 2012 at 20:28:56 from (75.65.124.221):
My pto is starting to stop and start at its own time line. It will stop altogether and then will start again. I am assuming that a clutch pack is needed, but can;t figure out why it runs fine at times and is dead for a while. Any ideas on where I need to go to get it working reliably again?
