You need to remove the gas line at the carburetor and see if there's a full flow of gas from the tank to the carb. Hold a clean container to catch the gas. If it's just a trickle your tank needs cleaning. If there's a full stream of gas from the tank remove the tube fitting from the carb and look for a screen behind the fitting. If it's clean I would clean the carburetor by soaking in carb cleaner and use air pressure to blow out the jets. If that carburetor has main jet adjustment scr/w you need to open it as this will enrich the fuel mixture. If that carb. has a solenoid that shuts off the gas it may not be opening fully. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
