Trouble shooting 101 The moment it stops check spark. It needs to be a blue/white spark that will jump a 1/4 inch gap or more. If it does not have spark hot wire it as in run a wire from the ignition side of the battery to the coil I am guessing it has a distributor. Then check for spark if still no spark probably a bad condenser. If you have good spark check for gas flow by pulling the drain plug out of the bottom of the carb and let it flow for a few minutes. Catch it so you can look at it for dirt/rust/water. No flow then work back to find where you loose it
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
