Re: 48 H mag timing
Posted by gene bender on July 03, 2012 at 11:43:24 from (67.55.226.123):
In Reply to: 48 H mag timing posted by Kippster on July 03, 2012 at 09:37:01:
your mag on that tractor is made to fire on TDC make sure the rotor is pointed at the tower on the cap when it fires. Make sure #1 is at TDC and both valves are closed. You mite need to remove #1 plug to make sure and it wouldnt hurt to remove the tappet cover to make sure both valves are closed when the impulse fires if the rotor is off even one tooth it will make a difference. There is no advancing of the impulse on those mags it just fires on TDC or will be trouble getting it to start.
