Re: 48 H mag timing
Posted by El Toro on July 03, 2012 at 14:00:19 from (108.3.148.85):
In Reply to: 48 H mag timing posted by Kippster on July 03, 2012 at 09:37:01:
Hold your hand over the throat of the carburetor while a helper hand cranks the engine and see if there's good suction on your hand. You need good suction to pull that gas into the engine.
You may want to install a primer bulb so it squirts that atomized fuel into the air stream.
Your impulse coupling needs to be snapping so you get that hot spark when hand cranking. We had 10-20's and 15-30's and they started easily by hand cranking. We even used them in cold weather for hauling manure and sawing wood. If your H has a fully charged battery you can convert that mag to a distributor by using the points and condenser in the mag and installing an auto type coil. You would need to remove the wire from the mag's coil to the points and connect the hot wire from the new coil to the points. I would also check the magnets in your mag using a screwdriver to make sure they have good magnetism. It should attract that screwdriver with a lot of effort. Hal
