Posted by gene bender on July 03, 2012 at 17:36:27 from (67.55.226.123):
In Reply to: Farmall A steering posted by charlie M on July 03, 2012 at 17:10:11:
You start at the tierods they can be tightened if they are egg-shaped a disc grinder can make them with a calipers round again. Next is the arm coming off the steering sector is it loose on the out-put shaft. Thed internally the key holding the gear to the shaft then a bearing at the upper end. Then bushings some seals and you will be good as new again. Fill with 90wt so the worm and gear can run in lube. Ive done several with like new results when finished.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
