20 is a little fast, just use judgement and don't go faster than you feel comfortable with. Advantage of the 454 and other utilities is the low center of gravity. Yes without stabilizers it will wiggle on turns, should be ok straight, I usually raise the mower on 180 degree turns, less damage to the mower and also the ground surface. As Jimb2 said you can probably find some workable stabilizers.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
