Re: Farmall H specs
Posted by NoNewParts on July 04, 2012 at 05:33:51 from (67.240.145.25):
In Reply to: Farmall H specs posted by Mark Peters on July 03, 2012 at 09:16:04:
if the engine isn't completely worn out...........
some rings could be stuck in their grooves
also, lots you can't see even if it looks good from the top.
had a Super H that was oiling cylinders badly when I got it.
changing the oil, I stuck my pinky in the drain hole
to see how bad the muck was.
felt lots of pieces...........
pulled the pan and #1 and #3 pistons had broken skirts.
easy fix with new pistons, but pulling it apart,
everything looked perfect from the top.
