Re: 3pt stabilizers on 454 and similar tractors
Posted by jim23377 on July 04, 2012 at 05:46:38 from (64.121.20.149):
In Reply to: 3pt stabilizers on 454 and similar tractors posted by Teakettle on July 03, 2012 at 16:25:46:
I bought the brackets that go under the axles for my 574. I then used stabilizers off of a jd4720. They fit almost perfect. I don"t use them for brush hogging. I only use them when using the post pounder, post hole digger, etc. My mower is two heavy and I broke a stabilizer. I must have side swiped something with the mower. I managed to keep the chains on the inside with this setup. Make sure your chains are adjusted properly and adjust for the hills and you will be fine. I forget what it all cost but I think around 300 to 400. That"s a lot more than I wanted to spend. But once you start you have to finish.
