Re: valve adjustment
Posted by Bob M on July 05, 2012 at 07:59:45 from (69.207.87.163):
In Reply to: valve adjustment posted by BigTone on July 05, 2012 at 07:43:50:
Absolutely! You want to check/reset valve lash for couple reasons:
- It will never be easier (you've already got the rocker box off).
- Valve clearance WILL change when you remove/replace the head since the new gasket is likely be slightly different thickness than the old one. Also if the machine shop "cleaned up" the head gasket surface it will change the valve lash when reinstalled.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
