Posted by Tony_Idaho on July 05, 2012 at 09:56:49 from (137.201.242.130):
OK, I just took apart my Oil filled air filter. I noticed that when I pulled the air canister off, the engine ran much better. So I figured air flow. Took the clamp off the bottom, and found that there was little to none oil in the bottom of the canister, with some water. Proceeded to clean up, then looked at the main part of the air filter. Looks like it is made up of steel wool of some kind. but it is all gummed up with black sludge. I've tried break cleaner to no avail and also dunked in gas. It made the gas turn black pretty quick, but the sludge remains. Doesn't look like it was ever made to remove and replace with new steel wool, because it has notches punched into it so it doe not move.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
