Re: 200 runs rough, no power, dies
Posted by El Toro on July 05, 2012 at 10:14:47 from (108.3.148.85):
In Reply to: 200 runs rough, no power, dies posted by Dodge2500 on July 05, 2012 at 09:01:24:
Install a new set of points and condenser and see if the power improves. Also hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. See if you have good suction. Low suction means you have low intake manifold vacuum. Could be a vacuum leak, but do a compression check on all cylinders and see what readings you get. Hal
