Re: 200 runs rough, no power, dies
Posted by wayne in mn on July 05, 2012 at 12:56:37 from (64.118.12.213):
In Reply to: 200 runs rough, no power, dies posted by Dodge2500 on July 05, 2012 at 09:01:24:
Any engine needs 3 things to run well.
1. Strong enough compression, reasonably even on all cylinders.
2. Fuel: has to be fresh and atomized in the correct ratio. In other words, the gas cannot be too old and the carb needs to have all jets & passages clean and adjusted.
3. Strong-steady spark to all cylinders; use a jump gap tester with an open air gap of at least 1/4" to 3/8".
Instead of guessing as to the problem, perform some basic tests on each of the 3 systems to isolate the trouble.
