Re: Battery sixe for a 3 cylinder Deisel
Posted by Lmack on July 05, 2012 at 14:28:00 from (24.131.58.167):
In Reply to: Battery sixe for a 3 cylinder Deisel posted by Joe Rhodes on July 04, 2012 at 10:28:30:
As someone else has said get the most cranking amps you can fit into the space. It will not be the cheapest battery on the shelf. Diesels are rough on batteries. It is not when the inferior battery is new but when it starts loosing a little of its wump that you will wish for the better battery. Nothing like having a battery that will not first heat then spin you engine on a cold morning. If you are talking about a 3-cylinder you must be taling about a Perkins and they tend to start well in cold conditions if the battery is strong enough to spin it over.
