Re: H arcing
Posted by gene bender on July 05, 2012 at 19:32:55 from (67.55.226.123):
In Reply to: H arcing posted by Bill Bowen on July 05, 2012 at 13:38:31:
Like the other post said that sw and its mounting must have a good ground as its part of the charging system clean the mount up and your problem will go bye bye. When you are done use an OHM meter one lead on battery ground and the other on the sw mount housing.
