Re: oil pressure on Cub
Posted by Andy Martin on October 01, 2000 at 19:07:28 from (38.31.75.33):
In Reply to: oil pressure on Cub posted by Robbie on October 01, 2000 at 16:14:15:
How low is low?
I know that is your question too. If the needle moves to mid-range when it is cold, then settles to 1/4 range hot I would not worry about it, especially if it is not going to be worked hard.
Likely it needs the oil pump cover plate ground smooth. You access it by removing the pan. It can be ground using valve grinding compound on flat glass.
There may be other problems, and the oil pump may be OK.
Post A Followup
: Re: Re: oil pressure on Cub
