Re: M carb float and needle valve problems
Posted by rumplestiltskin on July 06, 2012 at 11:25:03 from (192.88.212.69):
In Reply to: Re: M carb float and needle valve problems posted by Marty from MN on July 06, 2012 at 10:12:24:
Hi, Marty.
If you've replaced or repositioned the bowl gasket, the float could be hanging up on it. I always trim the inside of the gasket to match the inside of the bowl rim.
Mark W. in MI
