Re: farmall 300 timing
Posted by wayne in mn on July 06, 2012 at 11:55:23 from (64.118.12.213):
In Reply to: farmall 300 timing posted by Evan from Iowa on July 06, 2012 at 11:25:40:
Timing should be at TDC when starting the engine.
IF you are at TDC on the compression stroke, turn on the ignition switch, rotate the distributor CW so the points are closed, then with the coil secondary wire (big wire) removed from the cap and near (1/4") metal ground, rotate the distributor slowly CCW until a spark occurs. Lock the distributor in place; you are timed!
