Re: M carb float and needle valve problems
Posted by rustyfarmall on July 06, 2012 at 14:08:35 from (67.55.162.174):
In Reply to: M carb float and needle valve problems posted by Marty from MN on July 06, 2012 at 12:24:57:
That pin shouldn't have any flat spots on it. There's your problem.
Also, pinch the slot together before you put the pin through the holes. You'll never get it tight enough with the pin already in there.
