Re: M carb float and needle valve problems
Posted by D Slater on July 06, 2012 at 18:45:56 from (184.15.36.245):
In Reply to: Re: M carb float and needle valve problems posted by rustyfarmall on July 06, 2012 at 14:31:37:
Pin sets around 3/16 inch to center back from the front bowl wall. Way the bowl is made there the pin only needs to be 1/8 to 3/16 inch longer if it has a 1-5/16 to 1-3/8 inch long pin to start with. Thats a ball park figure since some castings very some. Agree that most times the pin won't come out if the piviot frame is tight on pin at the sloted end.
