If you have a distribuor you need to have your points open and with the ignition switch in the on position use a test lite or volt meter and see if there's voltage to your coil. If there's no voltage check the ignition switch to see if there voltage on terminal feeding voltage to your coil. If there's no voltage here check the terminal on your switch that feeds battery voltage to your switch. If you have voltage to your switch replace the switch. If there's no voltage to your ignition switch you either have a bad connection or a broken wire. If you have voltage to your coil take some 320 wet or dry and rub the points until they're shiny. Then see if the engine will start. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
