Posted by gene bender on July 07, 2012 at 05:38:03 from (67.55.226.123):
In Reply to: Re: H arcing posted by Bill Bowen on July 06, 2012 at 02:53:20:
You didnt say you have an alt. Something is wrong somewhere are you sure you have it wired correct. The ground of all parts of the system is for a generator. Where is the Diode in the system better find out where you have something wired wrong before the Alt goes up in smoke. I just finished a SC with alt and was wired wrong and burnt up a new Alt they fed the 12v from the point side of the coil for beginers then had wire on posts 1@2 wrong.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
