F20 Starter Kit - replace Ring Gear
Posted by doehmke on July 07, 2012 at 07:17:23 from (67.233.244.36):
What's the best option to replace the ring gear on an F-20? I bought an extra engine for the starter parts, but the teeth on the ring gear are gone for several inches. I took the flywheel in to have it resurfaced and they offered to remove the ring gear. Unfortunately that meant cutting it off, so there's no option to rotate it on the flywheel. Though I suppose it could be welded...
I have a Farmall M ring gear that is almost identical, except the bevel on the teeth is on the opposite side from the original on my flywheel. Can I use the M ring gear as is? Or do I need to grind bevels on the correct side of the teeth so the starter drive can engage correctly?
Or are there any other options?
