Posted by rtr on July 07, 2012 at 13:19:28 from (74.248.177.68):
I have a Cub Cadet 100 Lawn Mower that is giving me trouble. I just acquired a wiring diagram, and decided to test some things. I remember reading somewhere where you said a simple "spark test" is relevant to trace down a problem. My problem is that when you hook up the battery, I get a spark on the (-) post when the lead is touched to it. The (+) post is already hooked up when this happens.
With the (+) post hooked up, and the (-) post disconnected; I decided to test the connections at the VR. I first disconnected the (F) wire, then touched the (-) cable to the battery, still got a spark. I re-connected the (F) wire. Then I disconnected the (BATT) wire from the VR, and did the same test at the battery. NO SPARK. I reconnected the (BATT) wire. I then, tried the (L) wire at the VR. NO SPARK at the battery. I then re-connected the (L) wire at the VR.
WHAT DOES THIS TELL ME? WHAT DO I NEED TO DO FROM HERE?
Also, FWIW this tractor is equipped with the 12 volt "starter/generator" combo
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
