Re: M carb float and needle valve problems
Posted by Ellis Kinney on July 07, 2012 at 13:43:16 from (74.136.71.201):
In Reply to: M carb float and needle valve problems posted by Marty from MN on July 06, 2012 at 09:28:13:
I had a similar problem. Don't ask me how the hinge pin becomes too short, but mine began falling out on one end and the float would not function. Simple fix. A 1/8 brazing rod is exactly the size you need. add a teeny bit in length and you're back in business. Ellis
