New points a lot of times have a coating on them to protect them so you need to use the flap from the box they came in to clean them. Tear off a flap then fold it in half and run it across the points a few times and see if that helps. Also to check your wiring run a hot wire from the battery to the coil ignition side and see if the spark is better. If it is then you have a wiring problem
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
