Re: Colby 560 is out of the paint shop... WOW
Posted by sflem849 on July 07, 2012 at 15:21:01 from (69.197.84.39):
In Reply to: Colby 560 is out of the paint shop... WOW posted by colby64 on July 07, 2012 at 14:37:47:
It will go together WAY quicker than it came apart. I'm not worried, you will make it.
I don't want to be a dick, but your wheel weights are on wrong. They should be turned 90 degrees. I can't see yours, but don't forget to flip them so the hand holds are both in the same direction/spot. If they are 180 off the hand holds wont be the same. I have four sets on my SMTA and I have to take them off to get them lined up right...I didn't realize they were screwed up until this spring.
