Re: Colby 560 is out of the paint shop... WOW
Posted by Kevin B from Illinois on July 07, 2012 at 15:36:15 from (173.20.194.215):
In Reply to: Re: Colby 560 is out of the paint shop... WOW posted by colby64 on July 07, 2012 at 15:24:13:
489 us correct about the weights you would not be able to change bolts on the axle if one was to come loose or brake, but it really looks good what year is it and where was it bought at.
