Re: Super C weak spark from coil
Posted by El Toro on July 07, 2012 at 16:46:24 from (108.3.148.85):
In Reply to: Super C weak spark from coil posted by Mike Layden on July 07, 2012 at 14:55:52:
Measure your battery voltage while cranking the engine to see how far the voltage drops. If the starter is drawing a lot of amps may not leave enough voltage for your ignition. Use a hydrometer and check the specific gravity in each battery cell and compare the readings. Should be the 1.270 range on a fully charged battery. If one cell reads very low you need a new battery. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
