Re: Farmall A idle miss
Posted by gene bender on July 07, 2012 at 18:53:19 from (67.55.226.123):
In Reply to: Re: Farmall A idle miss posted by kopeck on July 07, 2012 at 18:32:38:
I would still pull them and compare that could tell you there is a bad plug or bad wire. How are the tappets are they set at .14
