Re: Do I have blown head gasket
Posted by wisbaker on July 07, 2012 at 19:29:01 from (207.118.175.96):
In Reply to: Do I have blown head gasket posted by charlie M on July 07, 2012 at 17:32:46:
You figured it out water is getting into the cylinders. I'd pray for a head gasket, not that a bad head gasket is great but it's a lot better than the other possibilities (cracked head, block or leaking sleeve seals)
