Posted by farmallmick on July 07, 2012 at 21:04:38 from (166.137.88.30):
In Reply to: 300u Axle Seals posted by slifnom on July 07, 2012 at 17:05:00:
I'ts not hard to replace seals/gaskets. Make sure you drain, draw down axle fluid, or elevate axle before you start. Remove wheel, unscrew hub bolt, remove hub, unscrew 4 bolts which hold cap to axle housing. Remove old seal (in cap), install new seal, replace gasket. I was able to cross the IH seal part # at NAPA for 1/2 the cost. Good Luck!
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
