Re: Can I set valve clearance with a cold engine?
Posted by El Toro on July 08, 2012 at 03:56:46 from (108.3.148.85):
In Reply to: Can I set valve clearance with a cold engine? posted by dstates on July 07, 2012 at 20:57:35:
Bring No1 piston near the fan to TDC on the compression stroke. Then adjust valves 1-2-3 & 5 to .020"cold then rotate the engine 360 degrees and set valves 4-6-7-8. Hal
