Re: broken piston skirt
Posted by NoNewParts on July 08, 2012 at 05:10:27 from (67.240.145.25):
In Reply to: broken piston skirt posted by WVFarmall on July 07, 2012 at 17:22:09:
replace them
if money is too tight for a kit, just replacing those two
with new or good used,
is better than running it like it is.
Super H I worked on had two with broken skirts.
When I pulled them, I found they both had
no piston pin bushings at all.
not worn....they were not there
fixed that when I put in 2 new pistons and rings.
honed the sleeves and used a cast iron top ring set
(checked the other two and the pins/bushings were ok)
works fine
