Re: Should I paint as I go???
Posted by sflem849 on July 08, 2012 at 05:13:19 from (69.197.84.39):
In Reply to: Should I paint as I go??? posted by dstates on July 07, 2012 at 21:01:08:
If your final goal is a restored tractor I wouldn't do it. If you goal is a cleaned up and red tractor that will be fine. The biggest thing is you paint job is only as good as your primer. Rattle can primer is certainly not HVLP epoxy primer. The primer thickness and quality is just not there with rattle cans.
