IIRC the very last few production As had the engine provision for the SA use of a live hydraulic pump. Under the distributor drive there should be a plate (or cover) that when removed allows pump mounting. If it is not there, the two solutions are to mount a belt driven or front mount pump through the crank hole, or to swap engine blocks with an SC or other hydro equipped tractor. There is a possibility that the block was swapped out with a newer block during the tractors history, good luck. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
