Re: Broken camshaft gear (crankshaft timing)
Posted by Janicholson on July 08, 2012 at 08:21:10 from (96.24.99.126):
In Reply to: Re: Broken camshaft gear (crankshaft timing) posted by Mark Alayne on July 08, 2012 at 08:10:10:
Well it is inside the front pulley. I have been able to get a 3/4 drive socket on the nut and turn it. you can also remove the starter, and move the ring gear with a modest prybar. Raising one rear tire, using 5th gear, and rotating the tire will also allow engine rotation sufficient to do the job. Jim
