Posted by John G. Hasler on July 08, 2012 at 08:24:24 from (174.124.42.244):
In Reply to: Re: hey janicholson posted by Janicholson on July 07, 2012 at 20:05:16:
Janicholson writes: > Tying the neutral to the top of the casing is a > good idea.
No, _not_ the neutral. That should be connected to ground only at the service entrance. The green ground wire should be connected to the well casing. The pump frame should also be connected to the green wire as it is not reliably connected to the casing. If the pipe the water comes up is metal connecting it to the green wire is good enough (don't assume that it will be electrically be connected to the casing). If the pipe is plastic you should run a green (or bare) ground wire down to the pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
