Re: voltage regultor vs cut out
Posted by John T on July 08, 2012 at 10:34:02 from (66.87.0.166):
In Reply to: voltage regultor vs cut out posted by jim warehime on July 08, 2012 at 09:27:03:
Cutouts are smaller and theres only one relay inside, most are 2 terminal, BAT and GEN while a few older ones may have a terminal for grounding the gennys Field. On most, however, the gennys Field wires to a LHBD light switch which regulates the rate of charge.
A VR is bigger and either 3 terminal (BAT FLD GEN) or 4 terminal (BAT LOAD GEN FLD) and the gennys field wires to it instad of the light switch.
John T From Estes Park, Colorado today
