Re: Should I paint as I go???
Posted by sflem849 on July 08, 2012 at 12:00:49 from (166.181.3.156):
In Reply to: Should I paint as I go??? posted by dstates on July 08, 2012 at 11:19:22:
dstates said: (quoted from post at 11:19:22 07/08/12)
sflem849 said: (quoted from post at 07:13:19 07/08/12) If your final goal is a restored tractor I wouldn't do it. If you goal is a cleaned up and red tractor that will be fine. The biggest thing is you paint job is only as good as your primer. Rattle can primer is certainly not HVLP epoxy primer. The primer thickness and quality is just not there with rattle cans.
Do you have everything off the tractor when you paint it, then? Otherwise I assume you can't get behind the distributor and areas like that...
That's what I am doing on my 9. I will get you some shots of the piles. :) doesn't mean its right and it is a lot more work but it should be nice.
This post was edited by sflem849 at 12:03:21 07/08/12.
