You can adjust them with the engine at an idle. It would be easier to have one person with the feeler gauge and a helper doing the adjusting.
You also can jack up one of rear wheels as been mentioned and place the tranny in 5th gear after removing the plugs. Have the helper to rotate the wheel while you hold your thumb over the plug hole until feel pressure. Then drop a long plastic straw on top of the piston and then you watch the straw rise while the helper slowly turns the rear wheel. When it quits rising you can now adjust valves 1-2-3 & 5 counting from the fan end of the engine. Once these are adjusted to .020" rotate the engine 360 degrees and adjust 4-6-7 & 8. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
