Re: Hudraulics on Farmall A ?
Posted by gene bender on July 08, 2012 at 14:48:33 from (67.55.226.123):
In Reply to: Hudraulics on Farmall A ? posted by SugarTractor on July 08, 2012 at 07:19:33:
No you cannot put the pump from a SA on your tractor the block doesent have a place for it. You can run a hy pump off the pto or the belt pulley. Or you can have the front pulley machined and drive a pump out in front of the grille opening. I have a set-up for that system and otheres that will operate of either the pto or the belt pulley. What implements are you wanting to use as i also have levers for sifferent implements also cults. They can be lifted by hand and are easy to use. You can also use the exhaust system for lifting which i also have.
