Re: really at my wits end !
Posted by labman98 on July 08, 2012 at 16:51:15 from (208.81.196.42):
In Reply to: Re: really at my wits end ! posted by biggerred on July 05, 2012 at 19:41:02:
It will take around 1000psi min. to get the ps to work well. If you get a gage hooked up try the other auxiliary levers and see what the pressure goes to once the lever is engage and see how your PS works. Another trial is to remove the hose from the PS and see if you even get any oil out of it on its own without any levers pulled. If you get oil and the correct gpm then it"s not building pressure and by-passing somewhere. I have a clear diagram of the oil path if you are still working on it that should make sense of things. Shoot me an email and I will get it to you.
