Re: Magneto timing on H
Posted by rustred on July 08, 2012 at 16:59:59 from (184.151.222.235):
In Reply to: Magneto timing on H posted by BruceS. on July 08, 2012 at 16:17:10:
to get timing fine tuned to the mark, you need to: line up the pully to mark turning engine the way it rotates. put a piece of paper in between the points. then loosen the two mag bolts and turn mag opposite from normal rotation,may need to rock back and forth first but turn mag opposite of rotor rotation to set timing.as soon as you can pull paper from points you are statically timed. if run out of mag travel your one cog off on gear, so need to remove mag and reposition gear accordingly.
