Re: hey janicholson
Posted by Peculiar Farmer on July 08, 2012 at 18:24:57 from (209.105.137.91):
In Reply to: hey janicholson posted by glennster on July 07, 2012 at 13:48:43:
I worked for a small company years ago that did electrical and outdoor plumbing. We hung many submersible pumps. one in particular over 500ft deep on 160psi black plastic pipe. The only time we installed three wires was on pumps that had a control box with relay and capacitors above ground and required three wires to the motor. We did tape the wires to the pipe quite often and used plastic torque stops at varying intervals up the pipe to keep everything from rubbing against the side of the well. I replaced several that were tripping breakers and if a grounded one didn't, I would think it would have to reflect a faulty ground at the electrical panel.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
