Re: Sediment bowl assembly leaks
Posted by gene bender on July 09, 2012 at 04:04:51 from (67.55.226.123):
In Reply to: Sediment bowl assembly leaks posted by Abbby on July 08, 2012 at 19:27:39:
Get the nut loose all the way and the handle will screw out then you can replace the packing cotton string will work for packing or an o-ring does also work. The packing goes on the handle side of the washer. Mite want to use some sand paper to get the seat part on the end refaced so it doesent have any grouves and then it will work just fine.
