Re: Running rough at times
Posted by Janicholson on July 09, 2012 at 07:38:19 from (199.17.55.151):
In Reply to: Running rough at times posted by rt3460Ind on July 09, 2012 at 07:03:54:
My first check would be water or trash in the float bowl. If it is there, there might be more in the tank. A worn set of points can also do it. If it happens after running for an hour or so, and the coil is very hot when checked, It could be the coil. Jim
