Re: Running rough at times
Posted by old on July 09, 2012 at 09:47:46 from (209.86.226.27):
In Reply to: Running rough at times posted by rt3460Ind on July 09, 2012 at 07:03:54:
Pull the carb drain plug and let it drain for a couple minutes. Catch the gas so as to look for water/rust/dirt. Also check your spark it needs to be a blue/white and jump a 1/4 inch gap or more. Either one or both can cause you problems
